Date/Time: Sun, 19 May 2024 06:52:01 +0000
CTS FIX CONNECTION FAILURE
View Count: 750
[2019-01-03 01:44:56] |
Ziklag - Posts: 73 |
Hello, My CTS FIX CONNECTION connection worked perfectly until it stopped late evening of 2nd/01/2019 - since I did not touch as to alter my Data/ Trade Service Settings in any way and the said account logs in successfully using another (T4) Platform, then I am inclined to think that perhaps something changed at Sierra Chart's side and not on my local/ user installation. I need help, thank you. |
[2019-01-03 02:02:44] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-03 04:51:46] |
HTTPS www.sierrachart.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-03 04:13:04 HTTPS www.sierrachart.com:443 (2) | Connecting to IP: 46.4.97.203. | 2019-01-03 04:13:04 Reading Internal Order ID file. | 2019-01-03 04:13:04 Reading Trade Orders file. | 2019-01-03 04:13:04 Reading Trade Positions file. | 2019-01-03 04:13:04 Account Balance file. | 2019-01-03 04:13:04 Error binding to UDP port 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2019-01-03 04:13:04 Software version: 1842 32-bit | 2019-01-03 04:13:04 Usage end date: 2019-01-04 | 2019-01-03 04:13:04 Enabled for: Advanced Features. | 2019-01-03 04:13:04 Enabled for: Sierra Chart Historical Data Service. | 2019-01-03 04:13:04 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-03 04:13:04 Current selected Data/Trading service: CTS T4 FIX | 2019-01-03 04:13:04 Chart Update Interval: 500 | 2019-01-03 04:13:04 Time Zone: +03:00:00 (AST+03) | 2019-01-03 04:13:04 2019-01-02 20:13:04 Local computer time | 2019-01-03 04:13:04 2019-01-03 01:13:04 Local computer time in UTC | 2019-01-03 04:13:04 2019-01-03 04:13:04 Local computer time in SC Time Zone | 2019-01-03 04:13:04 2019-01-03 01:23:06 Server time in UTC | 2019-01-03 04:13:04 Local computer UTC time and Server UTC time difference: 603 seconds. | 2019-01-03 04:13:04 Notice: Your computer's clock is off by 603 seconds. For help with this, press the 'Send for Analysis' button. | 2019-01-03 04:13:04 Program path: C:\Top\ | 2019-01-03 04:13:04 Data Files path: C:\Top\Data\ | 2019-01-03 04:13:04 OS Version Number: 6.3 | 2019-01-03 04:13:04 Locale Setting: C | 2019-01-03 04:13:04 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-03 04:13:04 Checking for new symbol settings for service code cts | 2019-01-03 04:13:05 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-01-03 04:13:05 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-01-03 04:13:05 Warning: Caught an exception during the processing of a timer event. Source: c_MainMDIWindow::m_UpdateTimer | 2019-01-03 04:13:05 * Received 5 login tokens. | 2019-01-03 04:13:05 Symbol settings are up-to-date for cts | 2019-01-03 04:13:05 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2019-01-03 04:13:07 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 46.4.97.203. | 2019-01-03 04:13:07 Files to Open on Start up | Opening file: CL.Cht | 2019-01-03 04:13:08 CL.20190200.CME_NY 5 Min #1 | Reloading chart. | 2019-01-03 04:13:08 CL.20190200.CME_NY 5 Min #2 | Reloading chart. | 2019-01-03 04:13:08 CL.20190200.CME_NY 5 Min #3 | Reloading chart. | 2019-01-03 04:13:09 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:09 HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2019-01-03 04:13:09 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-01-03 04:13:09 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:10 HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:10 HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-01-03 04:13:10 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:11 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:11 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:11 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-03 04:13:11 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:11 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:12 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:14.60545=1372=A373=1058=Sending Time Accuracy problem10=182 | 2019-01-03 04:13:12 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:12 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:14.60545=1372=A373=1058=Sending Time Accuracy problem10=182 | 2019-01-03 04:13:12 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:12 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:12 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:14.60658=Received unauthorized messages while not logged in10=207 | 2019-01-03 04:13:12 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:12 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:14.60658=Received unauthorized messages while not logged in10=207 | 2019-01-03 04:13:12 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:12 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:12 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:12 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:12 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:12 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:12 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2019-01-03 04:13:12 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2019-01-03 04:13:12 HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2019-01-03 04:13:12 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:12 HTTPS www.sierrachart.com:443 (5) | Closed. | 2019-01-03 04:13:12 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:15 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:15 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:15 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-03 04:13:15 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:15 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:15 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:15 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:17.94845=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-03 04:13:15 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:15 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:17.94845=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-03 04:13:15 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:15 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:17.94858=Received unauthorized messages while not logged in10=219 | 2019-01-03 04:13:15 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:15 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:17.94858=Received unauthorized messages while not logged in10=219 | 2019-01-03 04:13:15 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:15 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:15 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:15 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:15 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:15 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:18 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:18 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:18 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-03 04:13:18 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:18 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:18 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:18 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:21.31445=1372=A373=1058=Sending Time Accuracy problem10=177 | 2019-01-03 04:13:18 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:18 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:21.31445=1372=A373=1058=Sending Time Accuracy problem10=177 | 2019-01-03 04:13:18 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:18 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:21.31458=Received unauthorized messages while not logged in10=201 | 2019-01-03 04:13:18 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:18 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:21.31458=Received unauthorized messages while not logged in10=201 | 2019-01-03 04:13:18 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:18 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:18 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:18 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:18 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:18 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:18 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:21 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:21 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:21 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:21 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:22 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:22 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:22 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:24.72345=1372=A373=1058=Sending Time Accuracy problem10=184 | 2019-01-03 04:13:22 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:22 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:24.72345=1372=A373=1058=Sending Time Accuracy problem10=184 | 2019-01-03 04:13:22 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:22 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:24.72358=Received unauthorized messages while not logged in10=208 | 2019-01-03 04:13:22 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:22 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:24.72358=Received unauthorized messages while not logged in10=208 | 2019-01-03 04:13:22 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:22 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:22 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:22 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:22 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:22 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:22 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:25 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:25 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:25 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:25 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:25 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:25 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:25 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:28.26845=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-03 04:13:25 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:25 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:28.26845=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-03 04:13:25 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:25 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:28.26858=Received unauthorized messages while not logged in10=216 | 2019-01-03 04:13:25 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:25 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:28.26858=Received unauthorized messages while not logged in10=216 | 2019-01-03 04:13:25 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:25 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:25 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:25 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:25 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:25 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:25 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:28 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:28 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:28 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:28 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:28 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:29 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:29 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:31.65445=1372=A373=1058=Sending Time Accuracy problem10=185 | 2019-01-03 04:13:29 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:29 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:31.65445=1372=A373=1058=Sending Time Accuracy problem10=185 | 2019-01-03 04:13:29 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:29 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:31.65458=Received unauthorized messages while not logged in10=209 | 2019-01-03 04:13:29 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:29 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:31.65458=Received unauthorized messages while not logged in10=209 | 2019-01-03 04:13:29 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:29 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:29 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:29 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:29 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:29 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:32 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:32 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:32 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:32 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:32 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:32 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:32 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:35.03045=1372=A373=1058=Sending Time Accuracy problem10=177 | 2019-01-03 04:13:32 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:32 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:35.03045=1372=A373=1058=Sending Time Accuracy problem10=177 | 2019-01-03 04:13:32 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:32 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:35.03158=Received unauthorized messages while not logged in10=202 | 2019-01-03 04:13:32 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:32 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:35.03158=Received unauthorized messages while not logged in10=202 | 2019-01-03 04:13:32 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:32 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:32 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:32 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:32 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:32 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:32 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:35 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:35 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:35 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:35 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:35 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:36 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:36 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:38.57945=1372=A373=1058=Sending Time Accuracy problem10=198 | 2019-01-03 04:13:36 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:36 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:38.57945=1372=A373=1058=Sending Time Accuracy problem10=198 | 2019-01-03 04:13:36 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:36 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:38.57958=Received unauthorized messages while not logged in10=222 | 2019-01-03 04:13:36 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:36 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:38.57958=Received unauthorized messages while not logged in10=222 | 2019-01-03 04:13:36 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:36 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:36 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:36 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:36 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:36 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:36 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:39 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:39 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:39 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:39 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:39 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:39 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:42.03345=1372=A373=1058=Sending Time Accuracy problem10=178 | 2019-01-03 04:13:39 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:39 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:42.03345=1372=A373=1058=Sending Time Accuracy problem10=178 | 2019-01-03 04:13:39 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:39 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:42.03458=Received unauthorized messages while not logged in10=203 | 2019-01-03 04:13:39 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:39 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:42.03458=Received unauthorized messages while not logged in10=203 | 2019-01-03 04:13:39 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:39 CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:39 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:39 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:39 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:39 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:39 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:39 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:42 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:42 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:42 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:42 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:42 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:42 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:42 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:42 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:45.43445=1372=A373=1058=Sending Time Accuracy problem10=186 | 2019-01-03 04:13:42 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:42 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:45.43445=1372=A373=1058=Sending Time Accuracy problem10=186 | 2019-01-03 04:13:42 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:42 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:45.43558=Received unauthorized messages while not logged in10=211 | 2019-01-03 04:13:42 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:42 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:45.43558=Received unauthorized messages while not logged in10=211 | 2019-01-03 04:13:42 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:42 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:42 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:42 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:42 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:42 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:42 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:42 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:45 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:45 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:46 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:46 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:46 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:46 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:46 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:48.87245=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-03 04:13:46 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:46 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:48.87245=1372=A373=1058=Sending Time Accuracy problem10=195 | 2019-01-03 04:13:46 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:46 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:48.87358=Received unauthorized messages while not logged in10=220 | 2019-01-03 04:13:46 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:46 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:48.87358=Received unauthorized messages while not logged in10=220 | 2019-01-03 04:13:46 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:46 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:46 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:46 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:46 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:46 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:46 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:49 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:49 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:49 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:49 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:49 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:49 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:49 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:52.30145=1372=A373=1058=Sending Time Accuracy problem10=177 | 2019-01-03 04:13:49 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:49 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:52.30145=1372=A373=1058=Sending Time Accuracy problem10=177 | 2019-01-03 04:13:49 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:49 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:52.30158=Received unauthorized messages while not logged in10=201 | 2019-01-03 04:13:49 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:49 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:52.30158=Received unauthorized messages while not logged in10=201 | 2019-01-03 04:13:49 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:49 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:49 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:49 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:49 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:49 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:52 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:52 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:52 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:52 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:53 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:53 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:53 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:55.65445=1372=A373=1058=Sending Time Accuracy problem10=191 | 2019-01-03 04:13:53 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:53 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:55.65445=1372=A373=1058=Sending Time Accuracy problem10=191 | 2019-01-03 04:13:53 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:53 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:55.65458=Received unauthorized messages while not logged in10=215 | 2019-01-03 04:13:53 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:53 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:55.65458=Received unauthorized messages while not logged in10=215 | 2019-01-03 04:13:53 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:53 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:53 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:53 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:53 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:53 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:53 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:56 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:56 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:56 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:56 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:56 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:56 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:56 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:59.04545=1372=A373=1058=Sending Time Accuracy problem10=189 | 2019-01-03 04:13:56 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:56 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:23:59.04545=1372=A373=1058=Sending Time Accuracy problem10=189 | 2019-01-03 04:13:56 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:56 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:59.04558=Received unauthorized messages while not logged in10=213 | 2019-01-03 04:13:56 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:56 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:23:59.04558=Received unauthorized messages while not logged in10=213 | 2019-01-03 04:13:56 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:56 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:56 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:56 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:56 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:56 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:56 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:13:59 CTS T4 FIX | Firm: PTP | 2019-01-03 04:13:59 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:13:59 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:13:59 CTS FIX: Sending the Logon message. | 2019-01-03 04:13:59 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:13:59 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:59 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:24:02.45345=1372=A373=1058=Sending Time Accuracy problem10=181 | 2019-01-03 04:13:59 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:59 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:24:02.45345=1372=A373=1058=Sending Time Accuracy problem10=181 | 2019-01-03 04:13:59 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:13:59 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:24:02.45458=Received unauthorized messages while not logged in10=206 | 2019-01-03 04:13:59 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:13:59 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:24:02.45458=Received unauthorized messages while not logged in10=206 | 2019-01-03 04:13:59 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:13:59 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:13:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:13:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:59 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:13:59 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:13:59 CTS FIX socket (1) | Closed. | 2019-01-03 04:13:59 CTS T4 FIX | Disconnected. | 2019-01-03 04:13:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:13:59 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:14:02 CTS T4 FIX | Firm: PTP | 2019-01-03 04:14:02 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:14:03 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:14:03 CTS FIX: Sending the Logon message. | 2019-01-03 04:14:03 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:14:03 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:24:05.95045=1372=A373=1058=Sending Time Accuracy problem10=186 | 2019-01-03 04:14:03 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:14:03 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:24:05.95045=1372=A373=1058=Sending Time Accuracy problem10=186 | 2019-01-03 04:14:03 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:14:03 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:24:05.95058=Received unauthorized messages while not logged in10=210 | 2019-01-03 04:14:03 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:14:03 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:24:05.95058=Received unauthorized messages while not logged in10=210 | 2019-01-03 04:14:03 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:14:03 CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:14:03 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:14:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:14:03 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:14:03 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:14:03 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:14:03 CTS FIX socket (1) | Closed. | 2019-01-03 04:14:03 CTS T4 FIX | Disconnected. | 2019-01-03 04:14:03 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:14:03 File >> Disconnect selected. | 2019-01-03 04:14:05 CTS T4 FIX | Disconnected. | 2019-01-03 04:14:05 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:01 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:01 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:02 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:21:02 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:02 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:02 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:02 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:05.32645=1372=A373=1058=Sending Time Accuracy problem10=181 | 2019-01-03 04:21:02 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:02 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:05.32645=1372=A373=1058=Sending Time Accuracy problem10=181 | 2019-01-03 04:21:02 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:02 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:05.32658=Received unauthorized messages while not logged in10=205 | 2019-01-03 04:21:02 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:02 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:05.32658=Received unauthorized messages while not logged in10=205 | 2019-01-03 04:21:02 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:02 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:02 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:02 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:02 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:02 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:02 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:02 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:05 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:05 CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:05 CTS FIX socket (2) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:21:05 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:06 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:06 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:08.70545=1372=A373=1058=Sending Time Accuracy problem10=185 | 2019-01-03 04:21:06 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:06 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:08.70545=1372=A373=1058=Sending Time Accuracy problem10=185 | 2019-01-03 04:21:06 * CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-03 04:21:06 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:06 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:08.70558=Received unauthorized messages while not logged in10=209 | 2019-01-03 04:21:06 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:06 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:08.70558=Received unauthorized messages while not logged in10=209 | 2019-01-03 04:21:06 * CTS FIX socket (2) | Signaling to core to close socket | 2019-01-03 04:21:06 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:06 CTS FIX socket (2) | Received socket Close event. | 2019-01-03 04:21:06 CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:06 CTS FIX socket (2) | Closed. | 2019-01-03 04:21:06 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:06 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:06 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:09 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:09 CTS FIX socket (2) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:09 CTS FIX socket (2) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:21:09 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:09 CTS FIX socket (2) | Socket gracefully closed by remote side. | 2019-01-03 04:21:09 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:09 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:12.18845=1372=A373=1058=Sending Time Accuracy problem10=185 | 2019-01-03 04:21:09 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:09 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:12.18845=1372=A373=1058=Sending Time Accuracy problem10=185 | 2019-01-03 04:21:09 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:09 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:12.18858=Received unauthorized messages while not logged in10=209 | 2019-01-03 04:21:09 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:09 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:12.18858=Received unauthorized messages while not logged in10=209 | 2019-01-03 04:21:09 * CTS FIX socket (2) | Signaling to core to close socket | 2019-01-03 04:21:09 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:09 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:09 CTS FIX socket (2) | Received socket Close event. | 2019-01-03 04:21:09 CTS FIX socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:09 CTS FIX socket (2) | Closed. | 2019-01-03 04:21:09 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:09 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:09 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:12 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:12 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:15 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:21:15 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:15 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:15 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:15 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:17.87545=1372=A373=1058=Sending Time Accuracy problem10=193 | 2019-01-03 04:21:15 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:15 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:17.87545=1372=A373=1058=Sending Time Accuracy problem10=193 | 2019-01-03 04:21:15 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:15 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:17.87558=Received unauthorized messages while not logged in10=217 | 2019-01-03 04:21:15 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:15 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:17.87558=Received unauthorized messages while not logged in10=217 | 2019-01-03 04:21:15 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:15 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:15 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:15 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:21:15 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:15 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:15 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:18 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:18 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:18 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:21:18 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:18 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:18 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:18 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:21.24845=1372=A373=1058=Sending Time Accuracy problem10=182 | 2019-01-03 04:21:18 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:18 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:21.24845=1372=A373=1058=Sending Time Accuracy problem10=182 | 2019-01-03 04:21:18 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:18 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:21.24858=Received unauthorized messages while not logged in10=206 | 2019-01-03 04:21:18 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:18 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:21.24858=Received unauthorized messages while not logged in10=206 | 2019-01-03 04:21:18 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:18 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:18 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:18 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:18 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:18 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:18 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:18 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:21 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:21 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:21 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 04:21:21 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:21 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:22 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:24.59545=1372=A373=1058=Sending Time Accuracy problem10=190 | 2019-01-03 04:21:22 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:22 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:24.59545=1372=A373=1058=Sending Time Accuracy problem10=190 | 2019-01-03 04:21:22 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:22 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:22 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:24.59558=Received unauthorized messages while not logged in10=214 | 2019-01-03 04:21:22 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:22 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:24.59558=Received unauthorized messages while not logged in10=214 | 2019-01-03 04:21:22 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:22 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:22 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:22 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:21:22 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:22 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:22 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:25 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:25 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:25 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-03 04:21:25 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:25 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:25 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:25 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:28.17945=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-03 04:21:25 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:25 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:28.17945=1372=A373=1058=Sending Time Accuracy problem10=192 | 2019-01-03 04:21:25 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:25 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:28.17958=Received unauthorized messages while not logged in10=216 | 2019-01-03 04:21:25 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:25 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:28.17958=Received unauthorized messages while not logged in10=216 | 2019-01-03 04:21:25 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:25 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:25 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:21:25 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:25 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:25 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:25 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:25 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:28 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:28 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:28 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-03 04:21:28 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:28 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:29 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:31.58045=1372=A373=1058=Sending Time Accuracy problem10=182 | 2019-01-03 04:21:29 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:29 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:31.58045=1372=A373=1058=Sending Time Accuracy problem10=182 | 2019-01-03 04:21:29 * CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:29 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:29 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:31.58058=Received unauthorized messages while not logged in10=206 | 2019-01-03 04:21:29 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:29 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:31.58058=Received unauthorized messages while not logged in10=206 | 2019-01-03 04:21:29 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:29 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:29 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:21:29 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:29 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:29 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:29 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 04:21:32 CTS T4 FIX | Firm: PTP | 2019-01-03 04:21:32 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 04:21:32 CTS FIX socket (1) | Connecting to IP: 74.201.6.199. | 2019-01-03 04:21:32 CTS FIX: Sending the Logon message. | 2019-01-03 04:21:32 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 04:21:32 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 04:21:32 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:32 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:34.97945=1372=A373=1058=Sending Time Accuracy problem10=197 | 2019-01-03 04:21:32 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:32 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-01:31:34.97945=1372=A373=1058=Sending Time Accuracy problem10=197 | 2019-01-03 04:21:32 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 04:21:32 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:34.98058=Received unauthorized messages while not logged in10=213 | 2019-01-03 04:21:32 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 04:21:32 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-01:31:34.98058=Received unauthorized messages while not logged in10=213 | 2019-01-03 04:21:32 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 04:21:32 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 04:21:32 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 04:21:32 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:32 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 04:21:32 CTS FIX socket (1) | Closed. | 2019-01-03 04:21:32 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 04:21:32 File >> Disconnect selected. | 2019-01-03 04:21:32 CTS T4 FIX | Disconnected. | 2019-01-03 04:21:32 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 07:40:47 CTS T4 FIX | Firm: PTP | 2019-01-03 07:40:47 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 07:40:48 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 07:40:48 CTS FIX: Sending the Logon message. | 2019-01-03 07:40:48 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 07:40:48 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 07:40:48 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-04:50:51.44045=1372=A373=1058=Sending Time Accuracy problem10=183 | 2019-01-03 07:40:48 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 07:40:48 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-04:50:51.44045=1372=A373=1058=Sending Time Accuracy problem10=183 | 2019-01-03 07:40:48 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 07:40:48 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-04:50:51.44058=Received unauthorized messages while not logged in10=207 | 2019-01-03 07:40:48 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 07:40:48 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-04:50:51.44058=Received unauthorized messages while not logged in10=207 | 2019-01-03 07:40:48 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 07:40:48 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 07:40:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 07:40:48 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 07:40:48 CTS T4 FIX | Disconnected. | 2019-01-03 07:40:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 07:40:48 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 07:40:48 CTS FIX socket (1) | Closed. | 2019-01-03 07:40:48 CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-01-03 07:40:51 CTS T4 FIX | Firm: PTP | 2019-01-03 07:40:51 CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-01-03 07:40:51 CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-01-03 07:40:51 CTS FIX: Sending the Logon message. | 2019-01-03 07:40:52 CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-01-03 07:40:52 CTS FIX socket (1) | Received socket Close event. | 2019-01-03 07:40:52 CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 07:40:52 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-04:50:54.80145=1372=A373=1058=Sending Time Accuracy problem10=187 | 2019-01-03 07:40:52 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 07:40:52 * FIX Message: 8=FIX.4.29=10335=334=149=56=50=T4FIX52=20190103-04:50:54.80145=1372=A373=1058=Sending Time Accuracy problem10=187 | 2019-01-03 07:40:52 * CTS FIX: Received a FIX message from an unknown sender. Expected "PTP", but received "". | 2019-01-03 07:40:52 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-04:50:54.80158=Received unauthorized messages while not logged in10=211 | 2019-01-03 07:40:52 * CTS FIX: Received a FIX message intended for a different target. Expected "SierraChart", but received "". | 2019-01-03 07:40:52 * FIX Message: 8=FIX.4.29=10635=534=249=56=50=T4FIX52=20190103-04:50:54.80158=Received unauthorized messages while not logged in10=211 | 2019-01-03 07:40:52 * CTS FIX socket (1) | Signaling to core to close socket | 2019-01-03 07:40:52 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2019-01-03 07:40:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-03 07:40:52 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 07:40:52 CTS T4 FIX | Disconnected. | 2019-01-03 07:40:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-03 07:40:52 CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-03 07:40:52 CTS FIX socket (1) | Closed. | 2019-01-03 07:40:52 |
[2019-01-03 04:57:54] |
Ziklag - Posts: 73 |
I'm so sorry! I've just remembered something to do with my VPS time/ clock, I reset it and this corrected the problem. Thank you great team - you're the best 2019.
[2019-01-03 07:07:03] |
Yes that is indeed the problem.
