Date/Time: Sun, 05 May 2024 07:05:48 +0000
alerts with comments
View Count: 812
[2019-01-02 22:20:04] |
Bedhog - Posts: 168 |
Hello Team, I write custom alerts like the following but sometimes I forget how the fields are used. Yes, they can be written np++ somewhere else, but right inside the alert condition box would be the best. Since alerts begin with the equal sign... is it possible to create comments with REM or the apostrophe ' in the alert condition box like this? =and(ID11.SG13>ID11.SG23,id15.sg2>id15.sg3,id19.sg2>id19.sg3) REM 'thing 11 cross up, thing15 cross up, thing19 cross down Thank you for all your hard work. |
[2019-02-06 15:33:55] |
Hello Team, Is there a verdict? Can we add a comment marker to allow remarks in the Alert Condition box ? BEFORE: =and( id1.sg1[-7]>id1.sg2[-7], or(id6.sg1>5,id6.sg1<-5), crossfrombelow(id1.sg1,id1.sg2), id9.sg1, id10.sg1>id10.sg2 ) AFTER: =and( 'compare that id1 thing 7 bars back id1.sg1[-7]>id1.sg2[-7], 'that id6 study has to be within spec or(id6.sg1>5,id6.sg1<-5), 'when those red and green lines cross crossfrombelow(id1.sg1,id1.sg2), 'when that directional flag has been set id9.sg1 'this id10 setting is going sideways 'add it back later 'id10.sg1>id10.sg2 ) Date Time Of Last Edit: 2019-02-06 16:56:48
[2019-02-06 17:38:05] |
This is not going to be supported.
[2020-05-23 20:44:22] |
Matt NL - Posts: 91 |
Can I also upvote this please? My alert code is starting to become impossible to read. =AND( ID10.SG5>0, WEEKDAY(BARDATE)<>0, BV>AV*1, ID13.SG1<=ID13.SG1[-1], ID12.SG1>=-50, ,ID8.SG2>=50 ID36.SG1 < ID36.SG2, OR(ID1.SG1>ID1.SG1[-1], ID1.SG1>25) , OR(BARTIME<= TIME(8, 00, 0), BARTIME >= TIME(8, 00, 00)), AND(ID43.SG1<ID43.SG1[-1], ID20.SG1<ID20.SG1[-1], ID38.SG1<=ID38.SG1[-1] ) ) |
