Date/Time: Sun, 05 May 2024 13:44:33 +0000
auto trading with amp
View Count: 1107
[2019-01-02 14:09:38] |
User996274 - Posts: 80 |
is it required that the window that has the auto trade system (ive programmed) also have a "trade window for chart"? does amp allow the auto trade feature? I have the visual signal for a trade but the DOM trade window did not enter also is it it required I have "enable auto trading" in the trade heading? If so should global be used vs chart? received a log entry "send orders to trade service is not consistent with 'trade>>simulation mode On setting" version 1700 fwiw Date Time Of Last Edit: 2019-01-02 16:00:55
[2019-01-02 19:03:03] |
The only answer you need here is related to this: received a log entry "send orders to trade service is not consistent with 'trade>>simulation mode On setting" Refer to:Automated Trading Management: SendOrdersToTradeService And you are also running an older version and need to update following the instructions here: Software Download: Fast Update We will not provide support for an older version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-19 12:41:56] |
after updating I still cant auto trade (sim or actual) the error message (In the trade service log) now states "general order error refer to trade service log for specific message for this trading error" am i missing something? global "auto trade enabled" is unchecked i am in sim mode the study is enabled I would like the AT system to work on only 1 chart at a time thnx |
[2019-01-19 21:13:20] |
fixed
