Date/Time: Sun, 05 May 2024 17:59:03 +0000
Accessing the Sierra Chart Exchange Feed along with TransAct service.
View Count: 972
[2019-01-02 04:09:09] |
User70416 - Posts: 19 |
I currently have Infinity/TransAct for futures trading. I want to chart certain stocks on my Sierra Charts. How do I access the Sierra Chart Exchange Data Feed using my Infinity/TransAct account?
[2019-01-02 08:37:45] |
Did you need real-time data for stocks? Or would just historical data be enough?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-02 08:40:01
[2019-01-02 17:21:21] |
I need real time
[2019-01-02 18:36:59] |
Therefore, just use the Sierra Chart Exchange Data Feed. You can find the instructions here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-02 19:13:05] |
Do I switch to Sierra Chart Exchange Feed, or do I use both feeds at the same time? will there still be a discount for being an active trader with Infinity/TransAct? |
[2019-01-02 19:18:12] |
There are no discounts available. You have to pay more for the data feed because you are with Transact. You can use this data feed while using Transact. Refer to: Sierra Chart Exchange Data Feed: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-02 19:18:17
