Date/Time: Sun, 19 May 2024 07:45:28 +0000
MEMORY
View Count: 996
[2019-01-01 15:30:52] |
User28317 - Posts: 147 |
IS THERE A LIMIT OF MEMORY TO YOUR SYSTEM? MY SYSTEM HAS 17 SYMBOLS, EACH SYMBOL REQUIRES 4 CHARTS (5 MINUTE, 15 MINUTE, 60 MINUTE AND DAILY) AND THERE ARE 2 MODELS. (17*2)4=136 CHARTS OPEN MY RAM SAYS LESS THAN 50% USED OF OF THE 32 GIGS BEFORE I OPEN ALL OF THEM BUT SIERRA CHARTS SAYS I'M OUT OF MEMORY ABOUT 80% DONE. |
[2019-01-01 20:44:56] |
Use the 64-bit version. Refer to: Software Download: Difference Between 32 and 64-bit Versions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-03 09:33:29] |
my software was built using the 32 bit.
[2019-01-03 18:18:49] |
This is incredibly simple just to recompile it as a 64-bit DLL. That can be done through Analysis >> Build Custom Studies DLL in the 64-bit version of Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-03 18:19:10
