Date/Time: Fri, 03 May 2024 03:14:58 +0000
Attached Trade Window does not update profit/loss twconfig filenames correctly if similar
View Count: 557
[2018-12-31 04:20:11] |
trader2017 - Posts: 91 |
There is a strange thing that happens sometimes when I name a series of target and stop orders that are similar. I exited the application and restarted it and that did not fix it. Have not tried reinstalling it yet, although I seem to remember doing that in the past by updating to a new version and that did not resolve the problem. If I add the following twconfig files, the first number is a reference to the profit target and the second to the stop loss which is zero for these examples. percent qty1 .01 0 percent qty1 .02 0 percent qty1 .03 0 Then I set each one to their respective profit target of .01 .02 or .03. When I select it from the drop down list in the attached trade window the parameters will update correctly in their fields but the name at the top will stay the same as the first one. The way around this is that I add some other characters such as extra periods to the name. Then it will update in the drop down list correctly. percent qty1 .01.twconfig percent qty1 .02..twconfig percent qty1 .03...twconfig |
[2018-12-31 18:30:32] |
This is a Microsoft software issue but we will implement a solution.
[2018-12-31 18:39:21] |
At least we think we can solve this. It would seem so but let us know after the next release is out. But if there is no change, then we cannot solve it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-31 18:42:27
