Date/Time: Sun, 05 May 2024 01:49:01 +0000
Study for HH and LL between two dates/times
View Count: 607
[2018-12-30 17:49:55] |
jakesans - Posts: 50 |
Is there a study that marks the highest high and lowest low between two date/time inputs? All I can find are similar based on number of bars.
[2018-12-31 18:59:41] |
Well one way to accomplish this is to adjust the Chart Settings to that particular date range: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#UseDateRangeFromTo And then use the study to cover that time range and display the lines: Previous/Period OHLC-Variable Period Refer to the following study for the ability to set a Start and End time within a day: High/Low for Time Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-31 19:00:44
