Date/Time: Sun, 28 Apr 2024 10:10:33 +0000
One click BuyStopLimits/SellStopLimits?
View Count: 664
[2018-12-28 02:15:27] |
User116783 - Posts: 84 |
Hello, I'm using a simple bracket order with MIT for target and Stop for Stop (which are already set up under the targets window). For entries, I would like to use BuyStopLimits and SellStopLimits (see attached image 12-19-51.png). Is there a way to initiate these with one click from the DOM without having to first select them from the drop down list (see attached image 21-13-03.png)? For example, when right clicking on the Buy/Sell columns, instead of a BuyStop or SellStop, the entry is a BuyStopLimit/SellStopLimit? Thanks, ZS Date Time Of Last Edit: 2018-12-28 02:37:50
2018-12-27_21-13-03.png / V - Attached On 2018-12-28 02:14:13 UTC - Size: 74.41 KB - 287 views 2018-12-27_21-19-51.png / V - Attached On 2018-12-28 02:20:42 UTC - Size: 70.64 KB - 283 views |
[2018-12-28 09:35:40] |
Yes this is done through Global Settings >> Chart DOM Settings: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-28 09:39:34
