Date/Time: Thu, 02 May 2024 15:45:00 +0000
5 renko can't handle the moves.
View Count: 1840
[2013-11-08 13:46:13] |
User31703 - Posts: 16 |
Can you tell me how to smooth out the 5 renko. When the market moves then the 5 renko gets jacked up. In order to make it look right I have to "reload and recalculate". Today after non-farm payroll news the market started jamming, and I had to reload and recalculate several times in order to view the chart correctly. In this case the 15 renko needed to "reload and recalculate" in addition to the 5 renko. Is there a solution to this messed up problem? http://www.sierrachart.com/image.php?l=1383917722123.png http://www.sierrachart.com/image.php?l=1383918122531.png and here's the after I reload and recalculate. http://www.sierrachart.com/image.php?l=1383918154977.png and 10 seconds later http://www.sierrachart.com/image.php?l=1383918214877.png I can't use the renko charts like this. I really want to use the renko charts. |
[2013-11-08 14:04:46] |
This is in a normal moving market. #irritating #messedup #canttradethis before http://www.sierrachart.com/image.php?l=1383919261712.png then after "reload and recalculate". This is what I need all of the time. http://www.sierrachart.com/image.php?l=1383919368673.png |
[2013-11-08 14:14:20] |
Again. Before reload and recalculate http://www.sierrachart.com/image.php?l=1383919938592.png After reload and recalculate http://www.sierrachart.com/image.php?l=1383920030977.png The "after" is what I need all of the time. |
[2013-11-08 14:20:49] |
crazybears - Posts: 314 |
Hi wht datafeed do you use ? |
[2013-11-08 14:28:30] |
I use whatever comes default from Infinity Futures. So I'm not sure. On my chart at Global Settings -> Data/Trade Service Settings shows "Service [trading]". Global Settings -> Data/Trade Service Settings -> SC Server Settings show Sierra Chart Server Settings if that indicates the data feed. Check out the time span too. This is in about 10 seconds time. Painful to watch, especially when I'm trying to see the price. http://www.sierrachart.com/image.php?l=138392065060.png Date Time Of Last Edit: 2013-11-08 14:31:24
[2013-11-08 14:35:08] |
does intraday data storage unit set 1 tick ? |
[2013-11-08 14:40:38] |
Right now at Global Settings -> Data/Trade Service Settings, the "Intraday Data Storage Time Unit" is set to 10 seconds. Should I set that to "1 tick"? That makes sense. |
[2013-11-08 14:44:28] |
yes 1 tick
[2013-11-08 17:12:55] |
Follow the instructions on this page: http://www.sierrachart.com/index.php?l=doc/doc_TickbyTickDataConfiguration.php Also, there is no need to post too many images. We are not going to look at them all, and it only creates more work for us and it actually causes this thread to be deferred to be reviewed later. The longer and more complex a thread is, the longer it will take to be reviewed . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-11 14:05:46] |
Answered. Thanks again.
