Date/Time: Fri, 03 May 2024 10:07:15 +0000
Futures Options - How to View Options Chain and Purchase?
View Count: 3128
[2018-12-24 22:42:26] |
User344276 - Posts: 65 |
I am interested in trading options however I can't seem to figure out where to view the option chain (which shows the pricing for the calls and puts). Is this available on Sierra Chart? Is it possible to purchase options with Sierra Chart? Thanks.
Date Time Of Last Edit: 2018-12-25 02:35:04
[2018-12-25 02:34:37] |
Refer to: https://www.sierrachart.com/index.php?page=doc/CQGTrading.php#OptionsSymbolFormat And make sure you use the latest release which is 1853. It has much more efficient listing of options and spreads. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
