Date/Time: Sun, 19 May 2024 22:31:53 +0000
Too many numbers after the comma. Help please
View Count: 642
[2018-12-24 16:53:43] |
User393766 - Posts: 1 |
Hi! I bad speak English, so I write with the help of Google translator. Please tell me how I can remove the extra numbers after the comma on the chart footprint? The data takes up a lot of space on the monitor. I will be very grateful, I could not find. If not difficult, it is better to show in the screenshot. Thanks http://www.sierrachart.com/image.php?Image=1545669504751.png |
[2018-12-26 06:10:11] |
This will be solved in the next release.
