Date/Time: Tue, 30 Apr 2024 14:50:08 +0000
Downloading too much data (CTS after FIX update)
View Count: 1261
[2013-11-08 12:51:01] |
User60161 - Posts: 5 |
Sierrachart is downloading the maximum amount of data for all charts (100 days) even with days to display/load = 5. Is there a way to fix this without changing the max historical days? TIA |
[2013-11-08 15:43:19] |
No. You will need to reduce the Global Settings >> Data/Trade Service Settings >> Maximum Historical Intraday Days to Download setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
