Date/Time: Sun, 28 Apr 2024 16:06:28 +0000
Tick Volume Indicator
View Count: 2942
[2018-12-23 10:25:16] |
Alberto Gauer - Posts: 121 |
Hi, Is there a way for the volume study to plot the data based on the total of up ticks and down ticks and not on the total of contracts traded? Like it is in forex. Would like to see this on futures, like in S&P for example. Thanks Date Time Of Last Edit: 2018-12-23 10:25:42
[2018-12-23 23:34:07] |
Use these studies: DownTick Volume UpTick Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-24 19:49:36] |
@Sierra So I have to load both studies, combine with the summing charts studies and display graph as histogram, is it correct? |
[2018-12-25 12:24:43] |
Can someone reply to the question above, please? Also, what if I wanted for the volume bar on the histogram to be painted with a different color if some condition is met? I wanted the volume bar to be colored pink if it has volume lower than the previous two bars. It keeps getting painted pink if lower than previous two bars, otherwise it is painted the default color. |
[2018-12-25 16:43:49] |
Your Sierra Chart account is expired. Do you have a paid account?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-25 18:45:19
