Date/Time: Sat, 04 May 2024 11:32:03 +0000
IB CFD symbol settings incorrect
View Count: 666
[2018-12-22 12:07:48] |
User44804 - Posts: 7 |
Hi, i'm having problem with the symbol settings for the CFD symbols of IB, especially IBUS30-CFD-SMART-USD-BAAVG The price display format and tick size are wrong (0.001 instead of 1 and 0.01 instead of 1 respectively). When i try to change it in the DOM under "Chart settings" i cannot uncheck the "Auto-set from data feed" box. At the same time the message "Symbol settings not found for current symbol" is displayed. What to do? Thanks in advance. |
[2018-12-24 20:18:05] |
We have now added this symbol. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that follow the instructions here: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
