Date/Time: Sat, 04 May 2024 21:32:08 +0000
Scale In/Out buttons on Control Bar
View Count: 623
[2018-12-21 17:10:23] |
samual sprat - Posts: 343 |
Hi, I've added the scale in/out buttons to my control bar and they work great to toggle the functions on and off. They don't however stay depressed when I toggle the functions on, so for example Scale In may be turned on, but the button doesn't reflect this and is popped out. I've got various other buttons configured and they depress correctly, so thinking maybe just an oversight Thanks S |
[2018-12-21 22:23:02] |
This will be supported in the next release.
