Date/Time: Mon, 20 May 2024 02:27:25 +0000
Order Entries
View Count: 833
[2018-12-21 12:04:58] |
Jeffrey S - Posts: 42 |
My DOM will only scroll down so far. It does not allow me to go up or down as much as needed. Is there a way to change this?
[2018-12-21 19:17:09] |
We can increase that range. Are you scrolling quite far away pricewise from the last trade price? For example what price are you trying to scroll to, and what is the last trade price and what is the tick size?
[2018-12-21 19:43:18] |
Sometimes up to 80 points from the current price.
[2018-12-27 14:13:59] |
I still haven't heard back on hop to increase the range for scrolling on the DOM.
[2018-12-27 14:47:25] |
This has already been increased and will be out in the next release.
