Date/Time: Tue, 07 May 2024 16:35:53 +0000
spread chart
View Count: 824
[2018-12-19 14:48:45] |
User831597 - Posts: 18 |
hi attached is spread chart two CL contracts 15 min.... is there possibility to see remaining time till end of one 15 min. line (period) ?? second question ....I didnt find possibility to set type of chart line with small point (dot) in moment of start new 15 min . period ..is it possible ?? |
spread1.PNG / V - Attached On 2018-12-19 14:46:46 UTC - Size: 29.06 KB - 286 views |
[2018-12-20 09:28:14] |
Support board .....any answer ...?????
[2018-12-20 13:42:20] |
i found countdown study so it is ok ...but please aswer for second question
[2018-12-20 17:18:25] |
Here is the documentation for the Countdown Timer study: Countdown Timer second question ....I didnt find possibility to set type of chart line with small point (dot) in moment of start new 15 min . period ..is it possible ?? Graph Draw Types Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-20 17:18:43
[2018-12-20 18:49:39] |
please check https://www.tradingview.com/chart/9fQ1k0aD/ it would help me to see this small blue point- small circle - at moment end/start old/new line |
[2018-12-21 19:28:56] |
???????? answer
[2018-12-21 19:33:04] |
We have no further answer for this.
