Date/Time: Sun, 05 May 2024 20:04:54 +0000
customize keyboard shortcut for chart replay
View Count: 1613
[2018-12-18 05:06:19] |
dtl-saw - Posts: 79 |
Can you add to the available buttons for "customize keyboard shortcut" the chart replay buttons for advancing forward and rewinding backwards (see pic with red arrows pointing to the buttons)? You currently have 3 of the replay chart buttons available for keyboard shortcut: 1) replay chart 2) play/pause 3) stop. I find that while using chart replay i typically use the advance and rewind buttons very often during a replay in order to get through uninteresting periods in the chart and it would be a big help during replays to be able to have these buttons available for keyboard shortcut allows for better concentration when replaying. Thanks |
post-2018-12-17_2302.png / V - Attached On 2018-12-18 05:03:22 UTC - Size: 29.66 KB - 405 views |
[2018-12-21 21:08:42] |
I posted this a few days ago, can SC comment on if doing this is possible?
[2019-01-31 12:14:43] |
User532012 - Posts: 10 |
I second this request. Can we have these "<<" ">>" buttons available through the keyboard shortcut menus. You have to take the focus off the chart with the mouse to use this feature at the moment kind regards. Date Time Of Last Edit: 2019-01-31 12:15:06
[2019-05-13 21:08:25] |
User37014 - Posts: 8 |
I would like to add a request for this as well. Kindest Regards. |
[2019-05-14 19:44:48] |
We will get these added to the next release assuming there are no unexpected complications.
[2019-06-09 02:39:42] |
works perfectly - thanks
[2023-09-21 03:24:31] |
Sylent - Posts: 6 |
Hi where can I edit the hotkey for skipping/rewind? thanks
[2023-09-21 14:04:27] |
John - SC Support - Posts: 31379 |
"Global Settings >> Customize Keyboard Shortcuts >> Chart >> Replay Chart >> Jump Forward/Jump Backward". Refer to the instructions for customizing Keyboard Shortcuts here: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
