Date/Time: Fri, 11 Jul 2025 18:08:43 +0000
Strange behaviour when populating sc.Input array
View Count: 1707
[2018-12-17 20:12:56] |
binaryduke - Posts: 378 |
It appears that either using non-consecutive members in the array (i.e. leaving unpopulated array members) or larger values results in strange behaviour: #include "sierrachart.h" SCDLLName("Custom Study DLL") SCSFExport scsf_TemplateFunction(SCStudyInterfaceRef sc) { if (sc.SetDefaults) { sc.GraphName = "Template Function"; sc.AutoLoop = 1; //Automatic looping is enabled. sc.Subgraph[0].Name = "Name"; sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE; sc.Subgraph[0].PrimaryColor = RGB (0, 255, 0); sc.Input[0].Name = "Float Input 1"; sc.Input[0].SetFloat(0.0f); sc.Input[3].Name = "Float Input 2"; sc.Input[3].SetFloat(0.0f); sc.Input[5].Name = "Float Input 3"; sc.Input[5].SetFloat(0.0f); sc.Input[38].Name = "Float Input 4"; sc.Input[38].SetFloat(0.0f); sc.Input[46].Name = "Float Input 5"; sc.Input[46].SetFloat(0.0f); sc.Input[125].Name = "Float Input 6"; sc.Input[125].SetFloat(0.0f); return; } } Only displays inputs [0], [3] and [5]. I have tested the array size iterating from 0 to SC_INPUTS_AVAILABLE and can populate the maximum number of inputs. I have repeated the test with a modulo function to only populate every other array member and this is fine too, yet the code above does not populate members 38, 46 or 125. Is there a need to ensure contiguous member usage of the sc.Input array? Date Time Of Last Edit: 2018-12-17 20:35:14
[2018-12-17 20:40:19] |
Yes you really do need to use these ACSIL Input array elements continuously.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-17 20:40:37
