Date/Time: Sat, 04 May 2024 10:15:25 +0000
Problem with study(Pivot Point - Daily)
View Count: 1338
[2013-11-07 17:02:49] |
User14266 - Posts: 225 |
I use the Pivot Point-Daily study on 3 different charts, which are all on separate chartbooks. I have this problem on on all 3 charts. I have the study set to calculate only 1 day. After the day is over, the previous days lines do not go away, and become connected to the current days pivots. The only way to fix this, is to remove the study from the chart. When I add the study back to the chart, it fixes the problem. See attached picture for a better description.
pivots.jpg / V - Attached On 2013-11-07 17:01:17 UTC - Size: 79.5 KB - 430 views |
[2013-11-07 17:15:36] |
One more thing....... This did not just start. It has been going on for a while. |
[2013-11-07 17:42:35] |
The easiest thing to do in this case is to select Edit >> Reload All Charts.
