Date/Time: Thu, 02 May 2024 18:54:31 +0000
quantity trouble
View Count: 1583
[2018-12-24 19:26:21] |
1234567 - Posts: 42 |
hello im still here. thank you
[2018-12-24 19:29:22] |
Yes we know and we were very preoccupied with other things over this weekend. We will be contacting you today. Just give us about 1 to 2 hours.
[2018-12-24 19:31:30] |
ok thank you
[2018-12-24 21:19:53] |
User has been called and explanation provided.
[2019-02-21 16:46:12] |
User917679 - Posts: 76 |
^^ Can this explanation be expounded upon? I feel like I'm having a similar problem(even after doing all of what was suggested in the above thread!) |
[2019-02-21 17:58:34] |
Fully express what exactly the problem you are having is.
[2019-02-21 19:37:23] |
Its actually alright, I just fixed it - It had to do with an ambiguity technicality whilst I was using multiple windows to trade - I fixed it by removing sameID-studies in the other linked windows(that seemed to cause the spreadsheet to read false entries..) It just seemed weird that that would cause these ''1 position'' random buys... but whatever.. Date Time Of Last Edit: 2019-02-21 20:21:48
