Date/Time: Tue, 30 Apr 2024 19:10:56 +0000
Thierd Party Studies
View Count: 1111
[2018-12-14 10:36:58] |
Dany3003 - Posts: 6 |
hy support team.i have a question. i have a source code and made a dll out of it. Sierra Chart load it in the custome study files and i can load it in chart and i see the settings but it does not work on chart?the indicator does not draw anything. but on my sierra chart account in the "Enabled Studies And Files Set To Download" section there isnt my study in it. How can i load my indicator into it? thank you in advance |
[2018-12-14 18:43:38] |
If you already created the DLL file and that is placed into the Data subfolder with the Sierra Chart installation folder you not need to be concerned with Enabled Studies and Files Set to Download. There is some other issue with the custom study. Would be best to start off with one of the Sierra Chart built-in studies as an example. The source code for those can be found in the ACS_Source folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
