Date/Time: Fri, 03 May 2024 05:20:55 +0000
PnL Format in DOM
View Count: 945
[2018-12-14 07:32:53] |
nicktrader - Posts: 665 |
Can't find the option to change the PnL Format in DOM (see pic). I'd like to change it in "ticks - ignore quantity" Many txs |
PnL Format.png / V - Attached On 2018-12-14 07:28:33 UTC - Size: 9.54 KB - 278 views |
[2018-12-14 08:58:03] |
Acro - Posts: 436 |
Chart - Chart Settings - Advanced Settings - towards the bottom right of that page
[2018-12-14 09:29:22] |
Many thanks. This option is known and from my point of view it only concerns the PnL in the Trade Window. But I'm looking for the PnL setting in the DOM. |
[2018-12-14 17:59:09] |
Refer to: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
