Date/Time: Mon, 29 Apr 2024 12:33:41 +0000
Volume Profile Tool and different symbols
View Count: 511
[2018-12-13 18:26:24] |
Stephan908 - Posts: 46 |
For manually drawn volume profiles using the volume profile tool, is there a way to hide them when you switch symbols like the other drawing tools (line, retracement, rectangle etc)? I have "Show Chart Drawings for Different Symbols" unchecked but I still see them when I switch symbols. I can see why it is happening since it shows up as a chart study but I was hoping there is a setting to tie volume profiles to the symbol since the profiles I draw for 1 stock usually don't apply to another stock I'm trading. I tried searching for this in the forum but didn't find anything related to this particular issue. Thanks! |
[2018-12-13 18:48:37] |
No, this is not supported. We will update the documentation to explain this.
