Date/Time: Mon, 29 Apr 2024 11:06:03 +0000
Zig Zag display text labels for greater than amount NOT Reversal amount
View Count: 560
[2018-12-13 17:49:44] |
sjk - Posts: 43 |
Is it possible to display a text label for all zig zags greater than 5 but NOT display the text label amount for the reversal amount of 2?
[2018-12-13 18:58:07] |
This is going to require custom programming. You can modify that study. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-13 19:11:18] |
sjk - Posts: 43 |
Thank you but I don't have that skill.
