Date/Time: Sat, 04 May 2024 09:21:02 +0000
Volume profile extending lines until they intersect
View Count: 735
[2018-12-13 16:45:32] |
bucks - Posts: 13 |
Is there a way to extend the volume profile lines over to the right until they intersect another volume profile or plot? I see an option for the TPO etc but not the volume lines themselves
[2018-12-13 18:39:35] |
What lines specifically? Anyway this can be done with the Value Area, Point of Control, and Peak and Valley lines. There are inputs for each of these: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=141&Name=Volume_by_Price#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-13 18:40:41
[2018-12-30 06:57:11] |
bucks - Posts: 13 |
Thanks I was wondering with the volume profile bars themselves can be extended right until they interesect another bar
[2018-12-30 22:05:40] |
No. The closest you can do is extend the Peak and Valley lines.
