Date/Time: Fri, 03 May 2024 11:13:22 +0000
the new sc cme datafeed request
View Count: 1209
[2013-11-07 13:40:38] |
User22396 - Posts: 191 |
for native exchange traded spreads can you have it so you don't have to setup every month and instead make it like a futures contract? for example iqfeed you setup the wti crude with 3 contracts...monthly, continuous contract and back adjusted continuous but for say the heating oil crack i need to create a new contract called QHOZ13-QCLZ13 and then when i trade jan i have to setup a new one called QHOF14-QCLF14...it would be nice if it was called something like QHOCL# and i just type the month code QHOCLF14 etc...cqg does it that way for native exchange traded spreads and it works fine... |
[2013-11-07 17:00:57] |
This will have to be reviewed much later on. This capability is not something that would likely be added anytime soon.
