Date/Time: Sat, 27 Apr 2024 13:59:05 +0000
Chart will not chage to previuos contract month
View Count: 467
[2018-12-13 15:04:58] |
User163798 - Posts: 4 |
everytime i switch back the chart to YMZ18 from YMH19 it stays on YMH19, will not allow me to switch back, any quick solution?
[2018-12-13 15:50:23] |
[2018-12-13 15:51:03] |
Any chance to sport my issue? Thanks |
[2018-12-13 15:56:27] |
Sawtooth - Posts: 3977 |
Go to Chart >> Chart Settings >> Main Settings tab, and uncheck 'Automatically Rollover Futures Symbol'.
[2018-12-13 16:01:08] |
[2018-12-13 17:31:13] |
Yes that is the option you need to uncheck. Relevant documentation: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-13 18:33:49
