Date/Time: Sun, 19 May 2024 06:51:51 +0000
issue with draw volume profile
View Count: 513
[2018-12-13 07:57:01] |
User884550 - Posts: 149 |
when drawing profile, it spoils part of the section with green lines as attached issue occured lately, earlier drawn profiles look ok and this bug happens on only 1 chart, drawing profiles on other charts is OK Date Time Of Last Edit: 2018-12-13 08:14:48
[2018-12-13 09:45:56] |
So you are saying those vertical green lines should not be there? Do you know what they are from? Try removing other studies from the chart through Analysis >> Studies and see if they go away.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-13 09:46:04
[2018-12-13 11:18:45] |
yes they should not be there, and I have no idea where they come from, not even confluent with other drawings on the chart. Also, it does not come from conflicting with other studies, I have simply duplicated this chart, and on exactly same duplicate draw vol profile works fine. I am ok with above solution, but only as long as its permanent. If any ideas how to make sure to avoid this in future, would appreciate your advise |
