Date/Time: Thu, 02 May 2024 15:04:17 +0000
FIX connection
View Count: 1153
[2013-11-07 13:40:20] |
RQ - Posts: 50 |
What does this mean? FXCM FIX: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 775680 | 2013-11-07 12:50:32 FXCM FIX: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 776071 | 2013-11-07 12:50:33 FXCM FIX: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 776452 | 2013-11-07 12:50:33 FXCM FIX: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 777220 | 2013-11-07 12:50:33 FXCM FIX: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 777446 | 2013-11-07 12:50:34 FXCM FIX: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 778526 | 2013-11-07 12:50:35 |
[2013-11-07 15:59:24] |
This means the FIX server on the FXCM side is dropping some market data messages.
