Date/Time: Sun, 19 May 2024 05:24:22 +0000
TNH9 the Ultra Bond Data Display is incorrect.
View Count: 680
[2018-12-12 14:25:19] |
IconBob - Posts: 61 |
TNH9 uses ZNH9 historical data. On one computer I can't find TN despite full symbol reset. Dat feed for both is Rithmic. I meant ultra note. Date Time Of Last Edit: 2018-12-12 14:27:57
[2018-12-13 08:53:30] |
This symbol has now been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After that open a new chart for it and re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-13 08:54:19
[2018-12-13 13:02:04] |
Thanks that fixed it.
