Date/Time: Sun, 05 May 2024 02:27:58 +0000
How to customize chart title bar
View Count: 2030
[2018-12-12 10:34:46] |
User150852 - Posts: 38 |
Currently the title bar contains also the full name of the contract which becomes very long the main issue is that if i add title to charts then in the CW menu i dont see the titles due to the length of the title bar is there a way to custom the title? i have tried global settings->Customize chart header but it does not affect the title bar |
[2018-12-12 18:27:24] |
User315969 - Posts: 10 |
This can be done through the Chart Settings: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) |
[2018-12-12 18:43:54] |
You will want to set a custom name here: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) And enable this option: Chart Settings: Use Title Bar Name as Tab Label (Chart >> Chart Settings >> Display >> Chart Display Items menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-12 18:44:08
