Date/Time: Tue, 07 May 2024 14:34:23 +0000
starting position in 1 chartbook creates opposite position in a different chartbook
View Count: 672
[2018-12-11 19:33:14] |
User326163 - Posts: 18 |
how do i break this link? for example, if i get long 1 ES contract, it will automatically go short 1 ES contract in a different chartbook. thank you |
[2018-12-11 20:14:11] |
Are you referring to simulated or non-simulated trading? Most likely simulated. Let us know. Make sure you are also on the current version of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-11 20:23:49] |
simulated, thank you
[2018-12-11 21:00:28] |
Update to the current version of Sierra Chart: Software Download: Fast Update Also refer to: Trade Simulation: Trade Simulation Position Quantity Calculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-11 21:46:06] |
i upgraded to latest version and created a second simulation account... BUT...when i check SIM1 it STILL creates the opposite position of the original SIM account. is there a solution? |
[2018-12-12 08:22:07] |
Can you attach screenshots of the Trade Positions quantity you see on each chart also showing the trade account identifier. Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image And we need to know what version of Sierra Chart you are running. You will see that on the title bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-12 08:22:28
