Date/Time: Wed, 08 May 2024 03:04:27 +0000
using multiple sim account
View Count: 834
[2018-12-11 17:18:20] |
User945742 - Posts: 12 |
hi i need some help on below, requirement is to backtest different strategy 1. i am trying to use sim1 and sim2 to test 2 strategy but can I see sim1 and sim2 order fills in chart separatly? 2. can i take snapshot backup in someway from sierra chart to save trade capture for 1year data? I already tested selecting sim2 from DOM but not working. kindly suggest |
[2018-12-12 18:14:55] |
1. Yes of course. This is inherently the case and cannot be changed. Not sure why you are asking the question because there cannot be a problem like this. Maybe you are not selecting the trade account on the correct Trade Window. Make sure you are selecting the trade account on the correct Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) 2. Yes refer to: Trade Activity Log: Importing and Exporting Data And refer to this setting: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#NumberDaysSaveTradeActivity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-12 18:16:29
