Date/Time: Sun, 05 May 2024 17:58:02 +0000
[Programming Help] - Code for HIGH > Highest High of last X bars
View Count: 1460
[2018-12-11 01:51:14] |
User121729 - Posts: 37 |
I want to do a color bar condition alert and want to have in the code the bar must have a High that is the Highest high of the last X bars... What would that code look like? H>????? Thanks |
[2018-12-11 04:27:10] |
Sawtooth - Posts: 3993 |
Since you can't use a range in Simple Alert syntax, the easiest way to do what you want is to add the Highest High/Lowest Low Over N Bars study, and reference it in the color bar's formula, like this: =H>ID1.SG1[-1] where ID1 is the HH/LL Over N Bars study. Otherwise your formula would look like this: =AND(H>H[-1],H>H[-2],H>H[-3],H>H[-4],H>H[-5],H>H[-6],H>H[-7],H>H[-8],H>H[-9]) ...etc. |
