Date/Time: Sun, 28 Apr 2024 10:06:08 +0000
Automatically assign TARGET CONFIGURATION
View Count: 1083
[2018-12-10 15:44:54] |
User51166 - Posts: 33 |
Is possible in next version add functionality into sierra chart: with change of quantity of traded contracts automatically chose default TARGET CONFIGURATION please see attachment. tHANKS
ASIGN TARGET CONFIGURATION.docx - Attached On 2018-12-10 15:41:38 UTC - Size: 108.45 KB - 333 views Attachment Deleted. |
[2018-12-10 19:57:00] |
You can do this using ACSIL: https://www.sierrachart.com/index.php?page=doc/Contents.php#AdvancedCustomStudySystemInterfaceandLanguage You have the ability to change the trade window configuration through ACSIL, but be sure you are running 1850 and you can also use sc.UpdateAlways and periodically check the current trade window order quantity. Here is the relevant documentation: ACSIL Interface Members - Variables and Arrays: sc.TradeWindowConfigFileName ACSIL Interface Members - Variables and Arrays: sc.UpdateAlways ACSIL Interface Members - Variables and Arrays: sc.TradeWindowOrderQuantity Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-25 21:02:46] |
ILIM KIRGIZ - Posts: 187 |
Dear Support, I use different presaved twconfig files for different scenarios. My programmer is developing a position sizing study which allows reading stop loss and entry price levels on the chart before entering a trade to set quantity, and attached order targets. Is it possible to read selected order type in trade window via a study? If yes, via which function? If we can read it from the trade window, our study will also fill the limit/trigger/stop fields in the trade window too. So our workflow will be as follows: selecting the twconfig file via trade window combo box while our study is active, It will read the parent order type. setting the stop level via our study (with a mouse click) setting the entry level via our study (with a mouse click) per order type into the relevant field (limit/stop/trigger) calculating the position size per risk tolerance and account balance (we developed a solution for that to obtain it from LMAX too) setting the targets (stop all and profit takes to attached order fields) In order to achieve this, we need to be able to read the selected parent order type in the trade window. Thanks. |
[2019-01-26 05:06:50] |
We did see your other post about this but we just have time now to review this. We can add this but it would be for an additional cost. About 50 USD.
[2019-01-26 09:17:17] |
Ok, I can pay for it. Please let me know your estimated duration for that as my programmer is waiting for it and how I can pay for this service. Thanks. |
[2019-01-28 21:30:25] |
We will try to get this done before the end of the week. You can add credit here if you do not already have that amount: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-01-28 21:31:05
[2019-01-29 18:23:05] |
Credit added for this purpose. Thank you. Please let me know when you are done. Thanks again. Date Time Of Last Edit: 2019-01-29 18:23:31
[2019-02-04 09:45:15] |
This is done but we have another issue we need to resolve before we can get a release out. Just allow about another 1 to 2 days.
[2019-02-07 18:18:00] |
Is there any update about this development? I scan through ACSIL trading document and I could view that to determine the status of an order it is first necessary to obtain the Trade Order data with the sc.GetOrderByOrderID or sc.GetOrderByIndex function. The current order status can be determined with the s_SCTradeOrder:: OrderStatusCode structure member. In the case of having 4 profit targets+common stop in attached orders configuration, Is there a way to determine the moment after Target1,2,3 reached (or only Target3 as it can't fill before Target1 and Target2) but Target 4 is an active status via a study/ACSIL? Thanks. |
[2019-02-07 22:20:31] |
This is done and documented here: sc.GetTradeWindowOrderType() The problem is in 1870 the actual function is misspelled in the header and we apologize for that. We are resolving this in 1871 coming out later today. In the case of having 4 profit targets+common stop in attached orders configuration, Is there a way to determine the moment after Target1,2,3 reached (or only Target3 as it can't fill before Target1 and Target2) but Target 4 is an active status via a study/ACSIL? Automated Trading From an Advanced Custom Study: sc.GetOrderFillEntry() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-09 03:24:00
