Date/Time: Mon, 06 May 2024 01:02:48 +0000
Simulation Mode Warning
View Count: 673
[2018-12-10 12:01:14] |
User566463 - Posts: 2 |
Hello, I've forgotten to switch out of Simulation mode a few times, and when I restart the system I don't pick up on the word sim in the header. Is there a setting to enable a warning message upon starting the system, or study (like clock-realtime) that would provide more visible notice on the chart. If not, would you consider adding some functionality as part of an up coming build? Thank you |
[2018-12-10 12:16:42] |
Xfanman1 - Posts: 320 |
Just as a suggestion that may help you. What I do is change my Trade Window background to another color that’s obviously different from my Live Trading Trade Window. This way it’s obvious to me which side of the platform I’m using. — Scott |
[2018-12-10 19:13:40] |
Refer to: Overview of Trading: Difference between Simulated and Non-Simulated Trading Modes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
