Date/Time: Thu, 02 May 2024 15:28:23 +0000
Support for 2 external data services at the same time
View Count: 480
[2018-12-07 19:03:20] |
Yes this is supported. You just need to install another copy of Sierra Chart. Refer to this page: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
