Date/Time: Sat, 04 May 2024 04:54:43 +0000
Extend Bar Value Until Future Intersection - what
View Count: 1276
[2018-12-07 08:41:13] |
User132748 - Posts: 159 |
I see in documentation "These extension lines are programmatically accessible through ACSIL with a special function" but which excactly is that special function? Is it sc.GetStudyLineUntilFutureIntersection()? May that function be used for any other native sc study that has extension lines option/feature (zigzag, etc)? Date Time Of Last Edit: 2018-12-07 08:43:19
[2018-12-07 18:17:22] |
Yes that is correct and we have updated the documentation to specify this clearly. And that function can be used with any Sierra Chart study that adds what are called future intersection lines. This does not apply to the zig zag study. The zig zag lines are contained in a single study Subgraph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-08 08:37:44] |
Thanks for explanation Regarding ZigZag study I meant its peaks' extension lines which are certainly NOT drawn as single subgraph (main zigzag line is single subgraph for sure). Date Time Of Last Edit: 2018-12-08 08:39:06
[2018-12-08 21:20:36] |
Yes you can access those extension lines with this ACSIL function: sc.GetStudyLineUntilFutureIntersection()
