Date/Time: Mon, 29 Apr 2024 11:29:51 +0000
[Programming Help] - ACSIL: how to enable/disable an attached triggered stop
View Count: 584
[2018-12-06 21:46:44] |
User525733 - Posts: 126 |
Hi, I have some confusion about handling attached orders through ACSIL. My understanding is that if i cancel the attached stop => i automatically cancel/exit all related orders...basically exit the position (if i was filled). I would like to be able to add a stop to a position (on or after order fill) and also cancel the stop (also after order fill) without exiting the position itself. is this doable through ACSIL? can it be done for triggered trailing stops as well? thanks |
[2018-12-06 22:13:14] |
When you cancel a Stop Attached Order, it has no affect on the position or even the related Target order. Refer to: Attached Orders: Attached Orders Functionality Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-06 22:14:39
[2018-12-06 22:18:30] |
got it...cancelling the attached stop of a WORKING ORDER will cancel the whole thing. Automated Trading From an Advanced Custom Study: Cancel Orders and Flatten Position Functions but how to ADD a triggered stop to an order that has already filled in ACSIL? |
[2018-12-07 01:08:30] |
