Date/Time: Sat, 27 Apr 2024 06:02:40 +0000
Display on Chart Orders / Delete Label Boxes
View Count: 1119
[2018-12-06 21:39:06] |
User371906 - Posts: 141 |
Hello, Can you please tell me if there is a way to take out the order labels when displaying orders on the chart as to be able to only see the line (point of entry and exit)? The boxes i would like to take out are in highlighted red box in attached picture. Thank you Regards g |
[2018-12-06 22:07:50] |
Refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-07 07:50:22] |
Thank You.
