Date/Time: Sat, 04 May 2024 14:48:20 +0000
Net Change
View Count: 742
[2018-12-05 01:48:08] |
User492288 - Posts: 28 |
Hello, Is it possible to display Net Change & Percent Change on chart using Text Display for Study or any other way, Net change hard to see on a chart header. Thanks Mark |
[2018-12-05 03:28:11] |
Acro - Posts: 436 |
YES Use Text Display for Study for both 1. Net Change - put on your chart daily ohlc and hide it - calculate the net change by putting on the study called study subgraphs subtract/difference and choose Last price off the main price graph and yesterday's close off the daily OHLC as the inputs and then hide this tudy too - put on your text display for study and point it at the output subgraph of your study subgraph subtract/difference study 2. Percent Change This is even easier as there are two built in studies - Percent since open and Percent since close Choose what you want and then point your Text Display for Study at that By the way, this is all in the documentation if you spend the time to read it and there is an infinite amount of creativity you can apply, again if you put in the effort |
[2018-12-05 04:18:27] |
Acro Thank you so much for your time. Just could not come up with idea how to do it. Thanks again, Mark |
