Date/Time: Fri, 03 May 2024 22:40:20 +0000
HOW TO SETUP MARKET-WATCH WINDOW (Comparable to MT4 & Tradingview)
View Count: 1053
[2018-12-03 23:08:24] |
User80732 - Posts: 26 |
How can I setup something comparable to the marketwatch window in MT4 and Tradingview?? (see attachments) I want a way to more easily and seemlessly change between currencies without have to go to chart settings. How can this be done? Thank you :) |
Market Watch.PNG / V - Attached On 2018-12-03 23:06:37 UTC - Size: 127.03 KB - 313 views tradingview.PNG / V - Attached On 2018-12-03 23:07:52 UTC - Size: 125.42 KB - 369 views |
[2018-12-03 23:11:39] |
TedMar - Posts: 189 |
check this Getting Quotes
[2018-12-04 02:17:50] |
You need to use a Quote Board for this and it does support changing the symbol of the chart. Refer to: Getting Quotes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
