Date/Time: Tue, 07 May 2024 09:40:52 +0000
CQG JSE DERivatives Futures contract
View Count: 852
[2018-12-03 20:15:55] |
tradermj - Posts: 5 |
Good day, Im trying to get the CQG JSE DERivatives Futures contract to work on Sierra. I cant seem to find it on your list. CQG gives the symbol as ALSI and month should be Z. Im still not able to find it or pull up the symbol. Do you perhaps know the correct symbol? |
[2018-12-04 07:29:07] |
We need to add this to the list of symbols. Just give us a couple of days to get this done.
[2018-12-04 07:42:23] |
I managed to get the symbol working. It was F.US.ALSIZ18. Im also subscribed for JSE Equity Data. How would I get this to display in Sierra. Lets say a stocks eg Naspers has a symbol of NPN. How would I need to enter it in Sierra? |
[2018-12-04 18:55:52] |
This symbol has now been added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will see the symbol listed in File >> Find Symbol. Lets say a stocks eg Naspers has a symbol of NPN. How would I need to enter it in Sierra? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-04 18:56:17
