Date/Time: Thu, 02 May 2024 10:08:56 +0000
Volume by Price settings
View Count: 1021
[2018-12-03 08:21:02] |
User308043 - Posts: 1 |
Hello, i have few questions about VbP. 1. Input: Ticks per volume bar it's by defold 5,i want to make 2, but i can't change this. 2. When i use "Draw Volume profile" tool for quick drawing it's working like study, not like drawing, and i can't erase this like simple drawing, i need go to studies and remove. It's not comfortable, how can i do this like simple drawing tool? Thank you in advance. |
[2018-12-03 19:04:19] |
1. The solution to this is explained here: Volume By Price Study: Ticks Per Volume Bar 2. Follow the instructions here for this: Volume By Price Study: Erasing Drawn Volume Profiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-03 19:04:48
