Date/Time: Mon, 29 Apr 2024 08:17:43 +0000
Chartbook Replay
View Count: 688
[2018-12-01 21:51:07] |
User794190 - Posts: 26 |
Every Saturday for several months now I replay point-and-figure charts for previous Mon - Fri, 6 am - 745 am. A couple of weeks ago, the replay began about 615 - even though the replay box had 600 and I had made no changes. But I could live with the loss of 15 min. Today the replays start about 640 am, even though the replay box still says 600 and I have made no changes. How do I correct this error? |
[2018-12-02 11:17:07] |
JanS - Posts: 46 |
I have noticed similar as well. I've just tested it, using a chart I had open: F.US.EU6Z18. Replay single chart standard starting 30 Nov at 08:00 GMT, skip empty periods not active. - Replay speed 1 --> replay starts at 08:06 GMT - Replay speed 100 --> replay start at 08:12 GMT I have used replay in the summer and did not notice anything like this. I then did not use it at all until last month when I did notice this behaviour. |
[2018-12-04 08:05:42] |
One reason for this is that if there is a noticeable amount of time to load the chart when you start the replay, then as soon as the replay starts at the specified Date-Time or the bar you started the replay at, there is going to be a fast advancement, depending on the speed of the replay, from that bar due to the elapsed time of the chart loading.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-04 08:06:18
