Date/Time: Sun, 19 May 2024 00:52:56 +0000
Spread order study from within ascil
View Count: 1007
[2018-12-01 20:36:28] |
CarlRostron - Posts: 80 |
Hi, I have been searching around for documentation on how I can use the spread order entry study you have available but from within ASCIL. I did want to use your spread order entry study within my code for managing my trades eg pyramiding the position. Is there any documentation or preferably an example piece of code to use the spread order entry study from within ASCIL at all? Thanks for any help |
[2018-12-02 23:58:04] |
The source code for this will be included in the next release. It will be installed to the /ACS_Source folder.
[2018-12-06 08:30:33] |
Hi I have just upgraded to Version: 1842 64-bit (25240:25241M). Will this example code reside in file tradingsystem.cpp ?Thanks |
[2018-12-06 11:06:50] |
You need to update to version 1849. And the file is SpreadOrderEntry.cpp.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-06 11:07:02
