Date/Time: Sun, 28 Apr 2024 04:50:10 +0000
Cursor menu
View Count: 1635
[2018-12-01 16:48:05] |
User629089 - Posts: 93 |
Hi, When you right click the cursor on a chart you get a menu including "pointer, line, ray, etc.. How can you delete/change these items within the menu? I had figured it out months ago and just can't remember what I did or find it within the documentation. Thanks |
[2018-12-03 20:34:05] |
Refer to the documentation here for this: Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
