Date/Time: Tue, 07 May 2024 06:46:47 +0000
History Data import (csv)
View Count: 1166
[2018-12-01 15:50:20] |
b3cker - Posts: 34 |
I have file with csv extension imported to correct data directory of SC. When I try to display chart I am getting message "Symbol setting not found for current service" and empty file with extension .dly is created. What am I doing wrong? How would I import history data for a symbol and continue to update it from the service? Is there a simple way? Thank You Date Time Of Last Edit: 2018-12-01 16:38:31
[2018-12-01 21:20:52] |
Update to the latest prerelease. Although you will still get the Symbol Settings error but can disregard that. Also make sure that the file extension is dly if it contains historical daily data and if you want it to be updated from the connected Data service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-25 14:33:03] |
User164231 - Posts: 278 |
Exporting and Importing Intraday Data Files Did I miss anything? I could not use the data for Daily, Weekly or Monthly? Is there a work around? Thanks. |
