Date/Time: Fri, 03 May 2024 11:55:26 +0000
Trade log file
View Count: 1399
[2018-11-29 04:11:18] |
User314803 - Posts: 1 |
Hi, I would like to import my trade log file to Edgewonk to manage my trading journal but i can't open the file. I asked them too but the problem still not solved. Maybe the account number is not correct: 314803. I use the trial version. Its a valid account number or i get a new one when i activate my account? Best regards, |
[2018-11-29 18:56:01] |
The trade account identifiers can be anything. They come from the external trading service you are using. Also we are going to be adding journaling capability to the Trade Activity Log in the next month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-03 22:44:23] |
NG1980 - Posts: 39 |
I'm excited for this Journaling capability
[2019-01-04 01:55:31] |
Thank you for the reminder. We will get to this as soon as possible.
[2019-02-11 12:05:46] |
ARDAN - Posts: 66 |
It will be great If you can also insert risked amount/stop loss level into the journal and to be reach it via external program for position sizing optimization purposes.
Date Time Of Last Edit: 2019-02-11 12:45:36
